Activity › Forums › Panasonic Cameras › HD footage with DVCProHD is 960×720??? Help!
  • HD footage with DVCProHD is 960×720??? Help!
    Posted by Niklas Wikman on March 15, 2013 at 1:02 pm
    So, I shot with our HPX500 and imported the clips using Log and Transfer. Codec is DVCPROHD but the resolution is 960×720 (PAL).
    It makes no sense to me. We used to shoot SD (DV50) and then all footage was 720×576 anamorphic.
    My final output will be SD DVD and/or web.
    Our main edit suite uses a Mac Pro with Aja IoHD for viewing. But we also edit using iMac 27″.
    Should I ingest the footage as ProRes422 rather than DvcproHD?
    Shane Ross replied 13 years, 6 months ago 3 Members · 2 Replies
  • Chris Tompkins
    March 15, 2013 at 2:30 pm
    That is correct. DVCPROHD is a “Thin Raster” format.
    Ingesting to Prores will not really gain you any quality.
    When making final output or master, you’ll have a full 720p file.
    Chris
  • Shane Ross
    March 18, 2013 at 5:04 pm
    Yup…as Chris says, there’s no problem. 920×720 is an Anamorphic HD format.
    Shane
    Little Frog Post
