Activity Forums Apple Final Cut Pro Legacy hd footage on a g5
  • hd footage on a g5
    Posted by Zack Massey on October 28, 2010 at 10:55 am
    I have a dual 2GHz PowerPC G5 with 10.5gb ram that I have been using for editing. I just recently started doing HD footage and it’s been running smooth. I have a 3 camera shoot that I synced up and want to use the multicam feature in FCP to edit. It freezes about every 4 seconds and can’t even preview the multiclip all the way. I have a internal 1tb scratch disk.
    My question is, is it time for a upgrade or is there something I can do to this box to get a little more life out of it?
    Thanks.
    Zack Massey replied 15 years, 11 months ago 2 Members · 2 Replies
  • Jeremy Doyle
    October 28, 2010 at 3:44 pm
    [Zack Massey] “I have a internal 1tb scratch disk. “
    Your hard drive is fastest enough to maintain the data rate of 3 HD streams. You’ll need a raid.
    How much throughput do you need? That depends on codec and frame size.
  • Zack Massey
    October 28, 2010 at 4:11 pm
    With only 2 internal drive bays, should I setup a raid using my primary disk?
    The footage I’m using is AVCHD 1440×1080 that was decompressed to Pro Res 422. Could the change to Pro Res be too much for this specific system?
    I’m wanting a final compression of 720p 30fps.
