Activity Forums Apple Final Cut Pro Legacy HD file to SD digi tape via AJA Kona 3
  • HD file to SD digi tape via AJA Kona 3
    Posted by Yiannis Valkan on July 11, 2012 at 8:46 am
    Hi all,
    I have a 1920×1080 at 25fps Prores 444 file and want to downconvert it from FCP 7 and AJA kona3 and output it directly to my DVW M2000P deck.
    Can someone pls tell me the procedure cause no matter what I have tried, the output quality is very low.
    Thanks.
    2 minds are better than one.
    Chris Tompkins replied 13 years, 10 months ago 2 Members · 1 Reply
  • Chris Tompkins
    July 11, 2012 at 2:09 pm
    SD will never look as good as the HD signal.
    If your card is outputting and down-converting and the edit is laying off to tape. You have everything right.
    Chris Tompkins
    Video Atlanta LLC
