Activity Forums Blackmagic Design HD Extremme HD to SD monitoring problem
  • HD Extremme HD to SD monitoring problem
    Posted by Douglas Villalba on June 25, 2006 at 5:28 pm
    Hello everyone,
    I just received my new HD extreme Friday but I am having problems monitoring HD. I can monitor DV and SD 8 bit, but I can’t monitor HDV, DVCPRO HD or Apple’s Intermediate 1080i 60.
    I am sure it is a simple setting, but I have read the instructions inside out and I can’t find my answer anywhere.
    My system settings setting are:
    Output: V&A connections SDI-Component
    Input: V&A connections SDI-Component
    HDTV UP/DOWN Converter:
    Outpt: HD to SD anamorphic 16:9
    Input: Off
    I can see a still image but no play back.
    I am sure that one of the Gurus has a quick solution to my problem and I thank you in advance.
    Douglas Villalba
    https://www.dvtvproductions.com
    dvillalba@dvtvproductions.com
    G5 QUAD 4.5 GB RAM, Decklink HD Extreme, HVX200, FX1
    Douglas Villalba replied 20 years, 2 months ago 1 Member · 1 Reply
  • Douglas Villalba
    June 25, 2006 at 5:58 pm
    Oh well, I guess that there is nothing that a little prayer can’t answer. I got my answer,but if there is someone having the same problem here is how simple it was. I had my View-Video Play Back to the monitor’s resolution and what I needed was the timeline video resolution. That simple, now I can start playi…. I meant working. 🙂
    Douglas Villalba
