Activity Forums Blackmagic Design HD Extreme output problems?
  • HD Extreme output problems?
    Posted by Steve Cohen on July 23, 2006 at 3:03 am
    I’m having problems getting video out onto my LCD monitor from Final Cut Pro 5.0.
    Monitor is a Advent LCD TV I have the component out of the HD Extreme going to the compnent in of the monitor.
    The monitor is set to 720p. I have tried 480i and 1080i and all I see is the desktop background.
    I can’t get Final Cut to play out ot that monitor.I have tried numerous setting on FCP, to many to remember right now and no luck.
    Can some one suggest a starting point.
    I don’t have any decks hooked up to the system at this point, I’m just trying to get Output monitoring setup.
    Steve Cohen
    Editor
    O2 Media Inc.
    Olivier Jean replied 20 years, 1 month ago 3 Members · 5 Replies
  • Kristian Lam
    July 23, 2006 at 11:19 pm
    Hi Steven,
    Have you used the easy setups we provide in FCP?
    Make sure you create a new sequence as easy setups do not affect existing ones.
    regards
    Kristian Lam
    Blackmagic Design
  • Steve Cohen
    July 24, 2006 at 2:00 am
    I don’t see any “Easy Setups”?
    When I go to Final Cut PRoooo > Easy Setup, there are nly the following choices.
    DV-NTSC
    DV-PAL
    DVCPRO HD – 1080i50
    DVCPRO HD – 1080i60
    DVCPRO HD – 720p24
    DVCPRO HD – 720p30
    DVCPRO HD – 720p60
    HDV – 1080i50
    HDV – 1080i60
    HDV – 720p30
    Offline RT NTSC
    OfflineRT PAL
    and Custom Setup.
    Thanks;
    Steve Cohen
    Editor
    O2 Media Inc.
  • Kristian Lam
    July 24, 2006 at 3:48 am
    Hi Steve,
    Please make sure you’re in an account with admin rights, then try reinstalling the Blackmagic drivers again. You can find the latest version on our site here:
    https://blackmagic-design.com/support/software/
    regards
    Kristian Lam
    Blackmagic Design
  • Steve Cohen
    July 24, 2006 at 11:30 pm
    Kristian;
    Thanks, that did it.
    I don’t understand, those were the same drivers I originally downloaded and installed.
    I never install drivers from the CD, becuase they are usually not current.
    Steve Cohen
    Editor
    O2 Media Inc.
  • Olivier Jean
    July 26, 2006 at 9:16 am
    you might have reinstalled fcp after
    you did install the BM Drivers.
    Regards
    Olivier Jean
    Video Sales Consultant
    Apple Certified Trainer Final Cut Pro 5
    Powermedia Systems
    Sydney Australia
