Activity › Forums › Blackmagic Design › HD Extreme doesn’t capture composite video correctly
  • HD Extreme doesn’t capture composite video correctly
    Posted by Dan Sparks on September 30, 2006 at 6:51 pm
    Has anyone else come across this problem? I know most of the time we use this card to capture SDI, or component video. Well, I had a need on a recent project to capture SD composite video. After making the proper adjustments to the Decklink pref. pane, I can see the composite video through the card to the Mac and to my NTSC monitor. However, the color is intermittent, or not there at all. Also tried using the Black Magic Deck Control program – same problem. Yes, I’ve tried the usual – cable swapping, PRAM resets, reference signal on and off, ect.. I running a 2.66 Mac Pro, OS 10.4.7, BMD 5.7 drivers, HD Extreme board, Final Cut 5.1.1. Has anyone else run into this, or would any of you with the same combo of gear be willing to try this and see what you get?
    Dan Sparks
    Tricom Video
    Dan Sparks replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
