Activity › Forums › Apple Final Cut Pro Legacy › HD DVCPRO50 Codecs on Windows?
  • HD DVCPRO50 Codecs on Windows?
    Posted by Dan Cowles on September 21, 2006 at 8:51 pm
    Hi —
    Is there any possible way to play HD DVCPRO50 footage that I’ve ingested from P2 cards, on a PC. I know this is a FCP only codec, but I’ve been able to play it on other non-FCP macs by installing the codec in the quicktime folder.
    Is there a way to do something like that on a PC?
    It’s problematic when non-Mac users need to work with the footage.
    David Roth weiss replied 20 years ago 3 Members · 2 Replies
  • Shane Ross
    September 21, 2006 at 9:58 pm
    Nope…no way to do this. Once you import it from the card it is not viewable on a PC, as there is no DVCPRO HD codec in Quicktime for PCs.
    Now…DVCPRO 50 or DVCPRO HD? Those are two different codecs. DVCPRO 50 is standard def.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • David Roth weiss
    September 21, 2006 at 11:15 pm
    [dancow] “It’s problematic when non-Mac users need to work with the footage.”
    Dan,
    That’s the very reason Apple paid to get an exclusive with Panasonic. I think Matrox may have a solution, but I’m not certain and even if they do it may not be available to non-Matrox users. I’d check on the Matrox forum and the P2 Forum if I were you.
    DRW
