Activity › Forums › Apple Final Cut Pro Legacy › HD CAPTURING ISSUES!!
Posted by Marc Steinberger on April 23, 2007 at 3:46 pmI shot an HD project using the Sony Z1u in 1080i…i’m using camera as a deck to import via firewire to my G5. Computer sees the deck but when i go to capture, an error message comes up saying, “Lack of incoming data from device.” Can anyone help? I have a deadline and need some advice.
thank you very muchKleoni Manoussakis replied 19 years, 5 months ago 6 Members · 7 Replies -
Lee Berger
April 23, 2007 at 4:38 pmWas the video shot on the Z1U? I ask this because I had problems with footage shot on a XL-H1 and played back on HVR-10U. It turned out that the H1’s recording speed was slightly off. Subsequent recording played fine after Canon made the repair.
Marc Steinberger
April 23, 2007 at 5:32 pmit was shot on the Z1u…i just called tech. support..they said it might be an OS issue and that when upgraded to 10.4, there are issues..anyone know about that?
Walter Biscardi
April 23, 2007 at 5:37 pm[cheetah] ”
it was shot on the Z1u…i just called tech. support..they said it might be an OS issue and that when upgraded to 10.4, there are issues..anyone know about that?”If you were running OS 10.3 and simply upgraded to 10.4, then yes, there can be a LOT of issues. Whenever upgrading from one OS to a new one, you should do a clean install. This means wiping out your hard drive, installing the OS and then installing all your software. Updates are fine to just install, but completely new OS is best installed from scratch.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”Read my blog! https://blogs.creativecow.net/WalterBiscardi
Marc Steinberger
April 23, 2007 at 5:45 pmis there a site to instruct how to wipe out like you said? I’m sure it’s a big procedure.
thanks -
Ben Oliver
April 23, 2007 at 5:52 pmpretty much back up any files on your hard drive that you wish to keep. unplug any ipods, firewire hard drives, etc. in fact, anything other than a keyboard and monitor and mouse, unplug.
pop in your tiger os install disc, restart, or whatever gets it to boot, do a CLEAN install, the one that will wipe your drive clean, and reinstal everything from scratch.
note, this will DESTROY everyting on your hard drive, backup everything you want to keep.
then, i usually run all the OS updates, then install FCP studio, then install all the updates, rebooting and restarting when it asks me. then I go and install all my other software, photoshop, squeeze, keynote, ilife, etc.
Steve Connor
April 23, 2007 at 6:59 pmWhat easy setup are you using?
Do you have deck control?
Is the camera set to 1080 or to auto?
Do you have i-link conversion set to “OFF”?
Kleoni Manoussakis
April 26, 2007 at 10:43 amI have the exact same problem,
its not your computer, dont wipe out your entire hard drive,
I have a MacBook Pro with the latest final cut, Mac OSX, and I get the exact same problem,
