Activity › Forums › Apple Final Cut Pro Legacy › HD capture in FCP6, now want standard def dvd output
  • HD capture in FCP6, now want standard def dvd output
    Posted by Graham Bull on January 10, 2011 at 3:43 pm
    i used QT conversion (mpg2) to output a dvd to standard def from a recent project captured/imported in HD. i may be wrong, but the result looked like sub-standard def. now working on a new project and have already imported HD clips. how do i go about creating a standard def dvd?
    Graham Bull replied 15 years, 8 months ago 3 Members · 3 Replies
  • Shane Ross
    January 10, 2011 at 4:23 pm
    You don’t do it via QT conversion. YOu use the DVD Presets in Compressor:
    #42 – Quick and dirty way to author a DVD
    Shane’s Stock Answer #42 – David Roth Weiss’ Secret Quick and Dirty Way to Author a DVD:
    The absolute simplest way to make a DVD using FCP and DVDSP is as follows:
    1. Export a QT movie, either a reference file or self contained using current settings.
    2. Open DVDSP, select the “graphical” tab and you will see two little monitors, one blue, one green.
    3. Select the left blue one and hit delete.
    4. Now, select the green one, right click on it amd select the top option “first play”.
    5. Now drag your QT from the broswer and drop it on top of the green monitor.
    6. Now, for a DVD from an HD source, look to the right side and select the “general tab” in the track editor, and see the Display Mode, and select “16:9 pan-scan.”
    7. Hit the little black and yellow burn icon at the top of the page and put a a DVD in when prompted. DVDSP will encode and burn your new DVD.
    THATS ALL!!!
    NOW…if you want a GOOD LOOKING DVD, instead of taking your REF movie into DVD SP, instead take it into Compressor and choose the BEST QUALITY ENCODE (2 pass VBR) that matches your show timing. Then take THAT result into DVD SP and follow the rest of the steps. Except you can choose “16:9 LETTERBOX” instead of PAN & SCAN if you want to see the entire image.
    Shane
  • Ronan Feely
    January 11, 2011 at 4:52 am
    Hi Shane,
    What do you mean by that “matches your show timing”?
    Ronan
    So all I did was pressed this button and then …
  • Graham Bull
    January 13, 2011 at 1:09 pm
    shane… you the man. really appreciate the step-by-step.
