Activity Forums Apple Final Cut Pro Legacy HD Broadcast monitor FCP Sync Issues!
  • HD Broadcast monitor FCP Sync Issues!
    Posted by Daniel Garriga on August 19, 2010 at 10:35 pm
    I have a Panasonic BT-LH1700WP HD monitor and I am having a hard time getting the external video option in FCP to sync with the monitor so the video plays. I have a Blackmagic Decklink 6.0 HD Extreme card and a BNC cable connected out of the card and into the SDI in on the monitor.
    I have gone to Video playback in the VIEW dropdown and have clicked HDTV 1080 options and it detects a signal, but… The
    John Fishback
    replied 16 years ago
    3 Members · 6 Replies
  • Walter Biscardi
    August 19, 2010 at 10:53 pm
    You probably need to set your Playback offset to 0. FCP defaults to 4
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • Daniel Garriga
    August 20, 2010 at 4:29 pm
    Ok, did that. But now I’m not even getting ANY picture. Not even when i click single frame and show current like I was getting before. The signal is there but no picture.
  • John Fishback
    August 20, 2010 at 9:08 pm
    In Video Playback do you have Blackmagic settings, too? I don’t know Blackmagic, but it’s probably similar to AJA’s Kona. Look for a 1080i 29.97 8-bit playback choice. And External Video should be set to All Frames.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Walter Biscardi
    August 20, 2010 at 9:33 pm
    [Daniel Garriga] “Ok, did that. But now I’m not even getting ANY picture. Not even when i click single frame and show current like I was getting before. The signal is there but no picture.”
    Double Check your Easy Setup. Playback offset has zero to do with you getting a picture or not.
    If you’re not getting a picture than your Sequence settings don’t match your Output Settings. Choosing the correct Easy Setup will be the easiest way to do this.
  • Daniel Garriga
    August 26, 2010 at 2:30 pm
    Thanks! I did that and now the only way I am getting picture is when I click SHOW CURRENT in the External Video option in VIEW. One frame of video comes up and stays there even when I play down my seq. If i stop it at another point in the SEQ and click SHOW CURRENT again then whatever frame i had it parked at shows up.
    How do i get this monitor to play the video?!
  • John Fishback
    August 26, 2010 at 4:46 pm
    I’m pretty sure it’s not the monitor. I saw similar things happen when we first got our monitor. Choosing the correct Easy Setup and confirming the parameters are correct is key. We were editing P2 DVCPro HD 720P23.98. What I found was making sure the framerate was 59.94 (not 23.98) and 8-bit (not 10-bit) for bit depth. Then the timeline played perfectly.
    John
