Activity Forums Apple Final Cut Pro Legacy HD 4:3 Pillar box to 16:9 1080HD
  • HD 4:3 Pillar box to 16:9 1080HD
    Posted by Kurt Waddington on August 28, 2009 at 12:34 am
    Hi all,
    Still trying to arrive at the best workflow/method to preserve quality or at least loose less from this HD pillar boxed 4:3 to full 16:9 HD.
    I’ve been uprezing Betacam footage through an MXO2 to 1080i59.94 in Prores 422 in order to preserve the largest amount of image data. Then I scale the 4:3 in FCP7 to fill the 1080 frame and position vertically to select the 4:3. This usually requires about a 136 % scale. Obviously softening the image very much. After this I render the timeline in the prores and send to Color. Grade in Color and send back to FCP7. At some point, either before sending to Color or after I need to do some editing and effects work as well.
    My question is, is there a preferred way/software to scale the pillar boxed 4:3? Presumably someone knows of a program that does this better than FCP7. Like Motion, Color or Compressor?
    THe MXO2 as of now doesn’t upres SD 4:3 to fill the HD 16:9 frame so I’m forced to do a 136% scale somewhere along the line.
    John Fishback
    replied 17 years, 1 month ago
    3 Members · 3 Replies
  • Shane Ross
    August 28, 2009 at 12:49 am
    Shake, After Effects…
    Shane
  • Kurt Waddington
    August 28, 2009 at 8:23 pm
    Thanks for your help Shane. I believe I have an Older version of Shake on my system somewhere. My AE is still only 6.5.
    Kurt
  • John Fishback
    August 28, 2009 at 10:13 pm
    Compressor with Frame Controls on and best quality selected should scale better than FCP – and faster as it can use all cores.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
