Activity Forums VEGAS Pro HD 30p to SD-DVD render progressive ?
  • HD 30p to SD-DVD render progressive ?
    Posted by Enrique Orozco on April 23, 2009 at 11:57 pm
    I’m beggining to produce DVDs (SD) from EX3 1080-30p shoots… testing workflows, and understanding the differences between HD vs. SD timelines, render settings, even HD camera settings, etc. … very good results….. one question remains unanswered from my tests… is it better to render PROGRESSIVE in the final mpeg2 DVD arch file (low field order is default)… will the final DVD be really progressive played on a capable-player and TV/monitor ?? … does it make any sense ??
    regards
    Enrique Orozco R.
    iDEA DigitalVideoStudio
    Enrique Orozco replied 17 years, 4 months ago 2 Members · 2 Replies
  • Douglas Spotted eagle
    April 24, 2009 at 12:12 am
    Rendering to 30p SD is just fine, particularly from 30p source, and from HD source.
    If the display is 30p capable, it’ll show 30p. If not, it displays as interlaced.
    Either way, it’s more flexible and higher end quality than hoping for a good deinterlacer and rendering interlaced media
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Enrique Orozco
    April 24, 2009 at 12:26 am
    thank you so much… and one final question.. if I “mix” interlaced and progressive sources on my timeline, what is the best render setting recomendation ?
    thank you again….
    Enrique Orozco R.
