Activity › Forums › Adobe After Effects › HD 1280×720 59.94 and 29.97 fps
  • HD 1280×720 59.94 and 29.97 fps
    Posted by James Orlowski on November 20, 2008 at 2:21 pm
    So, I’m rendering a clip out of AE CS3 at 1280×720 resolution using Photo JPEG Quicktime compression. The comp is set at 59.94fps. The output module is set to use that frame rate, too.
    But when I import the clip into my AJA Xena HS 1280×720 59.94fps job, it comes in at 29.97fps. And on the timeline, it requires rendering, and plays back in slo-mo.
    BUT, if I force the interpolation of the clip in the Premiere bin to 59.94fps (using the “assume this frame rate” setting), the clip plays fine with no need to render a preview.
    What gives? If I play that clip in the Quicktime player and show the inspector, the clip IS 59.94fps.
    I tried several times with different settings in AE, but whatever I do, the clip always imports into Premiere at 29.97.
    Of course, I could just assume the proper frame rate in the Premiere project, but for more than a few clips, that could get tedious.
    Thoughts?
    James Orlowski
    RYNO Production, Inc.
    http://www.rynoproduction.com
    800-860-7966
    James Orlowski replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
