Activity Forums Adobe After Effects HD 1024×720 to 720×576
  • HD 1024×720 to 720×576
    Posted by Aslan Tamek on April 21, 2012 at 3:45 pm
    hi everybody
    i have rendered an HD project in after effects which was 1027×728. as we are sendeing it to be broadcasted on tv, they have requested it to be 720×576.
    i made a composition in ae, sized 720×576 , the same fps (25), and i put the rendered project in it and scaled it, and then i used letterboxer to fill the blank upper and lower areas.
    then i render this down’rez composition.
    the problem is:
    the is quality loss, specially the titles and texts seem blured and noisy.
    thank you for any help on this.
    Architect & Animator
    Aslan Tamek replied 14 years, 5 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    April 21, 2012 at 9:39 pm
    You could render from your original comp and tell AE to resize the image to 720×576 with a widescreen pixel aspect ratio. There is no need to letterbox unless you know all screens this will be send to are 4:3 (most likely the vast majority will be 16:9 in which case your piece will look right)
    Quick tip, when rendering from AE, no need to render twice if you need various formats – hit the “+” next to your output module and add another output size. AE will render once and produce two files (my mouth was open for a while when I learned about this feature…).
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Aslan Tamek
    April 23, 2012 at 3:02 pm
    thank you so much Ted.. and about the AE feature you mentioned, that’s really amazing, unbelievable!
