Activity Forums Panasonic Cameras HC-X1000 card slot 1 is not working
  • HC-X1000 card slot 1 is not working
    Posted by Beth Pike on October 18, 2019 at 3:44 pm
    Hello,
    I’ve been using the HC-X1000 camera for several years. In recent months, the SD card slot 1 is no longer working. I can see images recorded on it while it’s in slot one (it was recorded on slot 2 and then viewed on slot one), so you can see images recorded in a separate slot. However, it will not record from slot one. So, therefore, the auto SW is not working. I have to record on slot 2 and then switch out the cards. My settings are correct on the camera. It seems to be a tech issue. Any troubleshooting work-arounds for it, other than sending in my camera for repair? Thanks!
    Beth Pike replied 6 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
