Activity › Forums › Adobe After Effects Expressions › Having Trouble With A Parenting Situation
  • Having Trouble With A Parenting Situation
    Posted by Filippo Marchetti on June 28, 2016 at 8:59 pm
    Hello; sorry for the slightly weird title but i have no other way to describe my issue and i need to solve it immediately.
    I am trying to animate the pedals of a bike rotating, but i’m having some trouble with the parenting.
    I’m trying to parent the pedal’s position to the pedal’s rotating axis (the metal tube), but if i try to do that the pedal snaps to the tube’s anchor point, which of course is not good.
    The problem is rather hard to describe, so i have shot a quick video showcasing it.
    How can i keep the position parenting while having the pedal in the correct position?
    Thanks.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    thisComp.layer("Front Pedal Bar Outlines").transform.position
    https://vimeo.com/revandesign
    Dan Ebberts replied 10 years, 3 months ago 2 Members · 6 Replies
  • Dan Ebberts
    June 28, 2016 at 9:31 pm
    Why are you using an expression for position rather than actually parenting the layer? I think I would parent the layer, then add a rotation expression to keep the pedal level.
    Dan
  • Filippo Marchetti
    June 29, 2016 at 1:35 am
    Thanks, would you kindly explain me how to do that? I’m not really into expressions.
    By the way is it possible there isn’t a quick way to parent only one propriety? Thanks.
    https://vimeo.com/studiomarchetti
  • Dan Ebberts
    June 29, 2016 at 6:50 am
    If the pedal is parented to the shaft, and you rotate the shaft, the expression to counter-rotate the pedal might be as simple as this:
    value -parent.rotation
    You might need to add an offset, depending on how you have things set up.
    Dan
  • Filippo Marchetti
    June 29, 2016 at 3:24 pm
    Thanks, i’ll try and i’ll let you know.
  • Filippo Marchetti
    June 29, 2016 at 4:15 pm
    It worked; thanks.
    For the future, could you tell me how to lock other proprieties? Thanks.
    I really need to learn expressions, but i can’t find decent courses.
  • Dan Ebberts
    June 29, 2016 at 7:08 pm
    Another approach would be to create a null and parent it to the crank at the pedal’s attachment point. Then you could use this for the (unparented) pedal’s position:
    thisComp.layer(“Null 1”).toComp([0,0,0])
    and the pedal should stay horizontal as the crank rotates.
    Dan
