Activity Forums Apple Final Cut Pro Legacy having trouble importing P2 files into Final Cut 6.02
  • having trouble importing P2 files into Final Cut 6.02
    Posted by Yuliya Lanina on February 19, 2008 at 2:28 pm
    Dear Creative Cow Crew,
    I am having problem importing some files from P2 into Final Cut 6. I see files in Log in and Transfer window but cannot import some of them into Final Cut. Most files import just fine but a few give unknown error. I have tried unchecking “remove advance pulldown” in the log in an transfer window, but that did not solve it. Any ideas?
    Thank you,
    Yuliya
    Tony Ostrovsky replied 16 years, 9 months ago 2 Members · 1 Reply
  • Tony Ostrovsky
    December 4, 2009 at 5:29 pm
    I’ve had this problem a couple of times. The following things helped at different times:
    1.Check your Firewire cable. It might be faulty
    2.Check 1394CONTROL settings (in case of Panasonic camera)
    3.Change the FCP machine (shouldn’t be a problem if you’re at uni)
    4.Make sure you have the latest P2 drivers for your Mac Os version.
    Hope it helps.
