Activity Forums Blackmagic Design Having trouble downconverting DVC proHD to SD
  • Having trouble downconverting DVC proHD to SD
    Posted by Sean Davison on April 4, 2006 at 9:17 am
    Im trying to play a DVC ProHD sequence from FCP 5.04. My timeline is set to DVC Pro HD, My Video out is set to Blackmagic 8 bit. My Monitor is connected to my Multibridge via YUV and the multibridge is connected to one of the SDI outs on the Pro HD Dual card. The monitor is only showing still frames and when I press play the Aspect ratio narrows. (The timeline plays fine) I have tried all the settings in the control panel.
    Damien Molineaux replied 20 years, 5 months ago 3 Members · 5 Replies
  • Kristian Lam
    April 4, 2006 at 11:16 am
    Hi Sean,
    What size and framerate is your DVCPRO HD sequence?
    We down convert 720p59.94 to NTSC, 1080i50 to PAL and 1080/23.98PsF and 59.94i to NTSC.
    regards
    Kristian Lam
    Blackmagic Design
  • Sean Davison
    April 4, 2006 at 1:34 pm
    1080i 50 pal – I jus need it to play out on a non hd pal monitor
  • Sean Davison
    April 4, 2006 at 6:00 pm
    Didnt realise you had to set video output to Blackmagic 1080i 50 ! Been trying to do it at sd 8 bit!
  • Damien Molineaux
    April 9, 2006 at 11:30 am
    I’m glad your problem is solved. I have a different problem, I can get an SD output with the software down conversion enabled in the Blackmagic preference panel and FCP set to HDTV50i 25 Hz (my timeline is PAL DVCproHD) but the image is clearly pixelated.
    Does anybody know how to activate the hardware down conversion, and is it better ?
    My system : G5 2x2GHz, 3.5 GB ram, Mac OS X.4.5, FCP 5.0.4, QT 7.0.4, Decklink drivers 5.4.2
    With my reagrds,
    Damien Molineaux
    earthling productions
  • Damien Molineaux
    April 9, 2006 at 11:50 am
    Sorry, I didn’t do my homework, hardware down conversion is apparently only supported on the Deckling HD pro. I guess with an HD plus I’m stuck with the software down conversion, however the quality is not satisfactory, what a disapointment. I will try and do a down conversion inside FCP and see if I get a better result, the only problem is it’s going to take many many hours of rendering.
    Cheers,
    Damien
