Activity › Forums › Apple Final Cut Pro Legacy › Having no luck exporting to 16:9 Widescreen
  • Having no luck exporting to 16:9 Widescreen
    Posted by Steve Caruso on February 10, 2011 at 1:17 am
    I’ve read a bunch of forums and tried everything but I must of messed up something up early on because I keep getting 4:3 even though I am changing all sorts of things anamorphic 16:9 , pixel rations to 853 x 480. Nothing it working.
    Here’s what I can tell you, I uploaded the footage on a G5 then transfered it to a Hard Drive and have been editing it on my mac, all the images were small on the canvas so I manually expanded all of them. (I’m thinking thats where I messed up) Does anyone have any idea how I can fix this up to be able to export correctly to 16:9. Need more info?
    Steve Caruso replied 15 years, 7 months ago 3 Members · 3 Replies
  • Michael Gissing
    February 10, 2011 at 5:22 am
    [Steve Caruso] “Need more info?”
    Yes. Sequence settings, file attributes, viewing setup, intended usage etc.
  • Paul Jay
    February 10, 2011 at 10:55 am
    A. all your clips are shot anamorphic and have the anamorphic flag in item properties.
    B. your sequence settings are SD Anamorphic.
    C. Copy your timeline. Select ALL , then remove attributes. Scaling and distortion.
    Timeline should be good now.
  • Steve Caruso
    February 11, 2011 at 2:18 am
    ^ this guy is a genius…thank you so much i searched hours trying to figure out where I went wrong.
