Activity › Forums › Adobe Media Encoder › Having difficulty creating preset with desired frame size
  • Having difficulty creating preset with desired frame size
    Posted by Mike Mackenzie on February 11, 2019 at 5:17 pm
    Hi everyone…
    My client gave me the following specs. I can get everything right except the frame size, which seems to default to 1440. I spent some time with Adobe tech support where I got to watch someone who has never used Media Encoder try to figure this out. Any help is greatly appreciated, this is what I need to create:
    MXF OP1a
    XDCAM HD 25 NTSC 60i
    1920×1080
    I can achieve all of this except changing the frame size to 1920×1080. Also FYI compression is not an area of expertise for me so be gentle…
    Motion Graphics Designer / Art Director
    Boston, MA
    Mike Mackenzie replied 7 years, 7 months ago 2 Members · 3 Replies
  • Mike Janowski
    February 11, 2019 at 7:18 pm
    XDCAM HD 25 60i doesn’t support 1920 x 1080. Your client is mistaken.
    https://en.wikipedia.org/wiki/XDCAM
  • Mike Janowski
    February 11, 2019 at 7:21 pm
    If he gives you guff, have him send you a sample clip of the frame size he needs to deliver, then open it in VLC or Switch (or Premiere) and check its Properties; then copy those into ME.
  • Mike Mackenzie
    February 11, 2019 at 7:28 pm
    Thanks, I figured something must be up with that. And I definitely appreciate the preemptive guff strategy!
    Boston, MA
