Having difficulty BREAKING APART and RE-ATTACHING audio from clips
I had thought that to break apart the audio from a clip you double clicked on the clip, but I can only do from the clip menu or SHIFT-COMMAND-G. Question in FXPX 10.0.7 when you have an audio track that is broken apart should it be green or blue (like the video track) because mine is green very similar to its colour if I DETACH the audio from the clip.
So then after I have edited the audio I am supposed to be able to double click on it and bring the video and audio back together but I cant. Also I dont see a menu item to do this either.
Can anyone help and please be gentle 🙂 as this is only my first week using the product.
Thanks in advance.
