Activity › Forums › Apple Final Cut Pro Legacy › Have you ever notced all the duplicate filters in FCP 5.1.2 or is just me?
Posted by Jeremy Garchow on January 16, 2007 at 5:43 amIf you set the effect availability to ‘all effects’ the fxplug versions are named exactly the same.
For example Gaussian Blur & you guessed it, Gaussian Blur
Why?
Jeremy Garchow replied 19 years, 8 months ago 3 Members · 4 Replies -
Peter Wiggins
January 16, 2007 at 9:52 amBecause this is the first implementation of FXplug in FCP, so you are seeing both effects available to you.
In the next coloumn should be which type of filter so you can choose.On the other hand, what else would they call it?
Peter
Jeremy Garchow
January 16, 2007 at 2:30 pmWell, if you use the filters from the effects tab, it’s easy to discern. I usually select filters from the effects menu and there’s no way of knowing what’s what. They could be called something like Gaussian Blur (fx) or Desaturate (fx). Anything that wouldn’t make it look like some sort of installation error. AS it is now if I select Gaussian Blur, I don’t know which one I’m getting, is it the new fxplug version or the original version? It’s a lot of unnecessary trial and error, you know?
Master of the obvious,
Jeremy
Tom Wolsky
January 16, 2007 at 3:14 pmThat’s why the default is only recommended effects. It adds in the Motion filters that are new but leaves out the duplicates. You can also go into the Effects tab and check the ones you want to work with. If you prefer the Motion blur with direction values, check it on. I check on all the filters, except the duplicates, and from the duplicates, check the one I prefer. Then turn on preferred effects.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Jeremy Garchow
January 16, 2007 at 6:07 pmLovely, thanks for the description, Tom. I tried finding that in the PDF manual, but alas it’s not in there. This is now making sense.
Jeremy
