Activity Forums Apple Final Cut Pro Have only offline media created outside FCPX. Relink later how?
  • Have only offline media created outside FCPX. Relink later how?
    Posted by Jiri Fiala on May 22, 2013 at 4:38 pm
    Hi!
    I’m embarking on this multi-cam narrative project and I’d very much like to do it in FCPX.
    I’ve been given these 352×288 MPEG4 Quicktime proxy clips via FTP, created probably with XDCam Transfer (C0001, C0002…). These MOVs are the only material I have access to.
    I know I can’t simply relink to high-quality media when I get them, but I need to start editing with these LQ proxies.
    Any workflow tips? Thanks!
    Jiri Fiala replied 13 years, 3 months ago 3 Members · 5 Replies
  • James Cude
    May 22, 2013 at 5:50 pm
    You can do this- as long as the final media matches the proxy in timecode, duration, audio channel configuration, frame rate and similar file name.
    • Basically all you’d do is first create a project at the delivery resolution- say 1080/24p.
    • Then add the proxy media into an Event. Keep everything well organized in the Finder before ingesting so you can refer back when it comes time to relink.
    • Keep all your proxies set to Spatial Conform-Fit in the Inspector. Don’t do a lot of keyframing/cropping/etc because you may end up having to redo a lot of that stuff depending on the different resolution of the high quality clips. Focus on the pure picture edit.
    • When you receive the high quality media- place it into a similar folder hierarchy as the proxy- again to make the manual relink simpler.
    • Then select the Event with the proxy media and File>Relink Event Files.
    • Select the Relink Option for All. Then point to the high quality media. If the names are the same it should match all automatically.
    I’d recommend doing an experiment with at least one example of proxy and high quality media to confirm that it works with your media.
  • Jiri Fiala
    May 22, 2013 at 5:58 pm
    Hm, it does seem to work. I had some instances in the past when this didn’t work, so I wrongly figured this wouldn’t be a supported workflow. Maybe it was some mismatch in audio channels.
    Cool, thanks!
  • James Cude
    May 22, 2013 at 6:28 pm
    Right on- glad that worked for you.
  • Jacob Brown
    May 23, 2013 at 12:04 am
    worst case scenario, if you have problems, you should be able to add mismatched media to the multicam clip after the fact. you can then sync the newly added clips. Then within the already created timeline simply switch the angle from the offline to the online.
    of course you wont want to do for the whole edit, but if its just a few clips that mismatch, its a fix.
  • Jiri Fiala
    May 23, 2013 at 9:32 am
    Yep, I’m sure it will come to that at some point 🙂
