Activity Forums Adobe After Effects Have a problem, could someone point my mistakes out?
  • Kevin Reiner
    April 25, 2012 at 5:43 pm
    Instead of animating the expand mask setting, I would actually animate the shape of the mask over time. Perhaps more than one mask to make it seem more random.
    Make a small mask in the middle of the circle. Instead of just a simple circle mask, adjust the points to encircle the parts of the image. Then go to the end of your animation and actually stretch out the mask until the image is totally revealed. Do a preview and adjust and make more mask path keyframes throughout the animation as you see fit. Then play with amount of feather (which can also be keyframed if needed). You will probably need to fade on the opacity at the very beginning of this animation.
    Not a difficult animation to accomplish, but kind of hard to describe.
    Good luck,
    Reins
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
  • Alexsander Dmitriev
    April 27, 2012 at 2:54 pm
    Ok, I will try that. Thank you so much 🙂
