Has Premiere killed Vegas pro?
Steele Rutherford replied 15 years, 11 months ago 9 Members · 33 Replies
Joel Mielle
July 24, 2010 at 11:18 pmNo I don’t work with H264, Vegas doesn’t handle it too well. I convert the files with Neoscene to AVI files. All runs smooth and well until it crashes. Computer doesn’t lock up, only Vegas comes up with error message. Frustrating as I put the very best recommended components in the system. Has to be Vegas as After Effects runs like a dream.
Filmmaker http://www.sixlovers.com
Ken Bennett
July 25, 2010 at 3:12 amHere is my system hardware:
Supermicro X7DWA-N, 16GB DDR2 FB-DIMM Mem, dual Xeon 2.83GHz 8-cores, NVIDIA GeForce 8800GT, RocketRAID 2313 & 2221 controllers, VideoToaster card, 500GB system drive, four 1TB storage drives, 4TB internal RAID-5 for video and 6TB external RAID-5 backup & 2nd video drive.Software:
Vegas Pro 9.0e, VT[5b] and Adobe Production Suite CS4. DirectX 10, QT Player 7.6.6, TMPGEnc and Firefox.OS: Windows 7 64-bit.
I recently did reload WIN 7. If this helps anybody, great. let me know the Good, the Bad and the Ugly.
Thanks.
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures! -
Al Bergstein
July 25, 2010 at 5:49 amJoel, the fact that you crash when you ‘push the spacebar to play the clip” is not a Vegas problem. Many thousands of us do that each day with Vegas with no crashes. I also work with Neoscene on Win 64, with no crashes (yet). The fact that you and a few others are having these problems does not point to Vegas being the problem. It points to something with your system.
Perhaps you are using a plug in that is not compatable with W64. Perhaps it’s some component of your system. Maybe something is failing. I have a very vanilla system, with only a eSata drive (external). I don’t use many plug ins, and the ones I use are supporting W64.
So go back to your hardware and strip out the oddities. Something is incapable, and you are likely to have it move with you to Adobe, or whatever other system you think will solve world hunger.
Good luck.
Alf
Norman Willis
July 25, 2010 at 9:48 am>>Joel, the fact that you crash when you ‘push the spacebar to play the clip” is not a Vegas problem. Many thousands of us do that each day with Vegas with no crashes. I also work with Neoscene on Win 64, with no crashes (yet). The fact that you and a few others are having these problems does not point to Vegas being the problem. It points to something with your system.
Norman Willis
http://www.nazareneisrael.org -
Steele Rutherford
October 28, 2010 at 6:39 pmI have Vegas Pro 9e 64 bit and Windows 7 64 bit but Vegas crashes every 5 F*^&*ing minutes. I’m only working on a three minute music video that has 6 video tracks on it. The video files are MTS or AVCHD. I have all the effects bypassed and it still crashes. I have 5 gb of ram, my processor overclocked to 3.08 ghz, and about a month ago reinstalled Windows 7. Why does Vegas keep on crashing, should I just trash it and go to Adobe?
Norman Willis
October 28, 2010 at 6:51 pmAs was said before, if your system is not stable under Vegas, it will not be stable under Adobe (or anything else).
What is your initial clock speed? I would back off the overclock. Something is not working for you, and the overclock seems to be a potential candidate.
Other than that, have you checked your RAM?
Norman Willis
Steele Rutherford
October 28, 2010 at 8:04 pmOriginal clockspeed is 2.8 ghz, and I have 5 gb of ram. I also have Vegas Pro 9d (haven’t updated it yet) on my laptop and it crashes all the time too. It’s really not that they crash but they become unresponsive. They lock up and say Not Responding.
Steele Rutherford
October 28, 2010 at 8:24 pmReset my clockspeed to normal, opened Vegas, made two changes to the timeline and it locked up.
Norman Willis
October 28, 2010 at 10:10 pmWhy not try 9.0e?
That seems to be the version that worked for most people. It should be a short download.
Norman Willis
Bill Mash
October 29, 2010 at 1:11 amI had some significant hair-pulling when I transitioned from NTSC DV to 1080p with AVCHD. It took me a combination of things that made thing progressively better. No guarantees / your mileage may vary.
Turn off media manager and disable all services that use it.
Check your event viewer, specifically application and systems for errors. Resolve errors you see and keep moving forward.
Split your OS paging file across multiple drives.
Don’t render to C:drive
Check disk space on all applicable drives.
Degragment early and often diskeeper is a great piece of SW for this.
Use enditall SW to kill all unnecessary processes before opening your editor.
Download a trial of Cineform Neoscene and convert to intermediate format and try editing with that.
Good luck,
~Just because you can doesn’t mean you should~
