Activity › Forums › Apple Final Cut Pro › Has anyone successfully imported Hi8 videotape into a Thunderbolt 3 Mac?
Phil Hyson replied 5 years, 5 months ago 7 Members · 15 Replies
Igzignious
March 26, 2021 at 4:12 pmThe most stable way I have imported Hi-8, VHS, mini-DV etc into a Mac is using a Blackmagic Intensity Shuttle bought on ebay (Thunderbolt or USB3) and using Media Express to do the import. I also have a in a TBC for the VHS import. After import then use FCP7 or X or whatever for editing.. Importing using FW800 into any of the NLEs or iMovie is fraught with problems .. timecode breaks etc.
Phil Hyson
March 27, 2021 at 5:15 pmAndy, thanks for the detailed info re: Sony Digital8. I’m using a Hi8 Sony CCD-TR101 (1993), the same camera I used to make the original Hi8 DV recordings. It does import via FCPX on my older TB2 Mac. Although the FCPX Preview window freezes while importing, the recording is OK. I have no idea why the FCPX window freezes though.
<font face=”inherit”>Apparently the Apple TB 3 to TB2 </font>converter<font face=”inherit”> does not work so I’ll give up on that.</font>
Phil Hyson
March 27, 2021 at 5:23 pmMy original Hi8 camera will transcode to digital. The issues are 1) Will work with TB2 (although with a frozen preview screen using FCPX, and 2) will not work at all with TB3.
Thanks all for the input.
As for long-term storage I plan to transcode into ProRes 422 and use Mark’s suggestion of Camera Archive for long-term storage. Hopefully those two thoughts are compatible.
BTW, has anyone compared FCPX transcoding to Apple’s Compressor transcoding?
Patrick Donegan
March 27, 2021 at 10:43 pm -
Phil Hyson
March 28, 2021 at 8:48 pmPatrick provided a great link. It confirms what I suspected all along, but had not found confirmation anywhere. The link confirms this: “When used to connect Thunderbolt 3 devices to a Thunderbolt or Thunderbolt 2 Mac, it must be a self-powered device. Bus-powered devices connected directly to that Apple adapter are not supported.” This is why my TB3 to TB2 adapter did not power up the digital converter. I will say that if your bus-powered device has a power plug, then it should work when plugged into a power source.
BTW, my Canopus ADVC-110 does have a power jack; it just does not come with a power cord.
Also, a Firewire 800, when plugged into a FW800 to TB2 adapter DOES work.
Thanks for the link Patrick!
