Activity › Forums › Adobe After Effects Expressions › Harry Frank’s Shatter Effect with Shard Control?
  • Harry Frank’s Shatter Effect with Shard Control?
    Posted by Mark Walczak on October 26, 2009 at 2:45 pm
    Hi Gang,
    I recently viewed Harry Frank’s excellent tutorial for doing a shatter effect with expressions. You may view the tutorial here:
    https://www.graymachine.com/2009/08/reverse-shatter/
    My question is this: Is there a way to control/manipulate the pieces as they assemble? As it stands, each of the pieces moves in a linear way (regarding its trajectory, no its rate of travel), and I was hoping to add some more character to its motion path. It would be great to do something as simple as applying a sine wave, but it was also be helpful to have more control over it. With my limited JavaScript knowledge, I tried to hack together something that would work, but to no avail. Hence why I’m here!
    Thank you so much in advance!
    What makes you explode?
    http://www.explosivegraffix.com
    Mark Walczak replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
