Activity Forums Corporate Video hardwiring a lav mic?
  • hardwiring a lav mic?
    Posted by Nelson May on December 6, 2007 at 6:19 pm
    I have no idea where to post this, since there doesn’t seem to be a pro sound category. I have some cheap Nady wireless lav mics, that I am running into an HVX200 standard DV. I can’t afford better mics right now so I have to make do with that I have. I am getting some dropouts and want to know if I can hardwire the lav to my camera XLR input, preamp or mixing board.
    I went to a Music store and everything we tried didn’t work. basically they tried to run a 1/8 inch mono to stereo adapter into a 1/8″ stereo to XLR (high to low impedance) It didn’t work.
    Would I be able to get a mono 1/8 phone plug and wire it to a Male XLR plug from Radio Shack?
    I know I won’t have the third line going to the XLR from the 1/8 inch plug, but is there a way to wire this to make it work?
    G5, 1.7, 4MB RAM, 30″cine, G4, 1.6 2MB RAM, Mbox, Neumann TLM-103, FCP HD 5. Pro Tools, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
    Rennie Klymyk replied 18 years, 9 months ago 4 Members · 4 Replies
  • Mark Suszko
    December 6, 2007 at 9:50 pm
    Do these mics require phantom power?
    Be wary when you’re going from balanced to unbalanced: if you cut one “leg”, you’re losing half the signal.
    Meanwhile, I’m thinking instead of cutting up your wireless stuff, even the $20 wired lav at Radio Shack is useable for some things.
  • Nelson May
    December 7, 2007 at 4:59 am
    i am not sure and am not sure if I have the spec sheet, but an engineer told me that if at least they take 1 volt it will not work.
    I wasn’t going to cut the cable, I was going to use a female 1/8 inch phono, center to pin 2 on the XLR, and the ring to 3 and 1 on the XLR.
  • 13 Create COW Profile Image
    13
    December 7, 2007 at 5:33 am
    It might be best to just rent a good mic for your shoot. The price of the adapters you might need could be close to the price of a daily rental fee.
    I gave up on cheep mics after my second one died on me, and since I don’t use them to often I just rent them now. At my local rental shop it is like $35 a day for a nice lav system.
  • Rennie Klymyk
    December 19, 2007 at 1:39 pm
    Look under audio professionals forum
    Basically you should match the voltages through an impedance transformer. I don’t know why the one at the music store didn’t work because that is what they do. Pro sound is Low-Z 600 ohm balanced audio which is the lowest power. Hi-Z is what your unbalanced mike is and it is really mid-level voltage and should interface with your pre-amp. Line level is hi-level voltage that is used in mixers, vcr’s etc.
    Attempting to link an unbalanced mic to the HVX200 is sinful. Get a balanced wired mic with an XLR end and save some headaches. Everyone should own 2 of these in their audio kit. Check these out at B&H
    https://www.bhphotovideo.com/c/shop/8535/Microphones_Lavalier.html
    Buy any one of these used on ebay. Sony for example ECM44B is a good starting point. Sony mics go up in quality to ECM55B; ECM66B; ECM77B; ECM88B. You should be able to find an ECM44B for $50.00 on ebay. Guys (like yourself in 3 years) will be dumping ECM44B’s to buy better quality replacements but for now they will be far better than your current set-up.
    “everything is broken” ……1st. coined by Esther Philips I believe.
