Activity › Forums › Apple Final Cut Pro Legacy › hardware/software requirements for P2 card
  • hardware/software requirements for P2 card
    Posted by Sue Mansfield on June 6, 2009 at 5:29 pm
    I have been using FC Pro 5.1.4 for several years to edit mini-DV tapes from our Sony A1U. I’m a biologist and not exactly FC savvy but I’ve managed to produce natural history footage for the North American Bear Center (https://www.bear.org). I have a procedure that works for me and I haven’t strayed much from it.
    We recently purchased a Panasonic HXP170 with P2 cards. I like the camera and the P2 card concept but I’m struggling with the learning curve. I’m able to download a file directly from the camera into FC Pro – but it comes in as one huge file rather that clips.
    We knew when we purchased the camera that our computer hardware/software setup was not ideal – but I’m looking for guidance on what I need to upgrade to make this all work smoothly.
    I’m currently running:
    Mac OS X
    Version 10.4.11
    Processor 4 x 2.5 GHz PowerPC G5
    Memory 6.5 GB DDR2 SDRAM
    Any help would be greatly appreciated!
    Sue
    John Fishback replied 17 years, 3 months ago 2 Members · 3 Replies
  • John Fishback
    June 7, 2009 at 1:31 am
    What procedure are you using to off-load the P2 cards? We do it by of-loading the P2 to a hard drive (actually 3 so we have backups). The files are copied to our RAID array then we use Log & Transfer to injest the files in FCP. Before upgrading to FCP6 we used FCP5.1.4 to do the same. It didn’t use log & transfer to bring in P2 media. Instead, in the Import menu I believe there’s a choice for P2. I’m not at the office and it’s been a while since I used FCP5 with P2 so I apologize for not being more exact.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Sue Mansfield
    June 9, 2009 at 5:29 pm
    Hi John,
    Thank you for your reply.
    I have been downloading the P2 footage via firewire directly from the camera into FCP. It’s quick and dirty but not a long-term solution. I just received new P2 e-series cards and will soon be inundated with footage to download to free those cards up.
    Your email has given me the courage to fire up an older notebook with a PCMCIA slot to see if I can download via it to a hard drive and import as you suggest. Can you recommend software to use?
    Thank you again — much appreciated!
    Sue
  • John Fishback
    June 12, 2009 at 2:52 pm
    We use Shotput P2 https://www.imagineproducts.com/ShotPut_P2_Edition.html
    John
