Activity › Forums › Apple Final Cut Pro Legacy › hardware downconversion
  • hardware downconversion
    Posted by Doru Iacovescu on February 26, 2009 at 11:48 am
    Hello! Do you experienced any kind of problems with the hardware based downconversion methods? Intend to buy an decklink hd extreme,but noy know if it s a good choice or not?
    Andy Mees replied 17 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Borjis
    February 26, 2009 at 5:28 pm
    [Doru Iacovescu] “Hello! Do you experienced any kind of problems with the hardware based downconversion methods? Intend to buy an decklink hd extreme,but noy know if it s a good choice or not?”
    I do.
    I own both aja and black magic (decklink)
    if you want proper down conversion with a sharp picture, get the AJA Kona-LHE instead
    of the Decklink.
    Decklink won’t down convert 720P.
  • Doru Iacovescu
    February 26, 2009 at 5:39 pm
    Thank you very much for your prompt answer! I was wondering; is it a noticeable difference beetwen this kind of conversion and the one made software only, let s say with compressor with the frame controls set to on and everything set to BEST? Can you achieve that clean, sharp, contrast, hollywood dvd style image with compressor? Is it worthing to invest in Cinema craft encoder plug in for compressor or a ahardware solution as you have?
  • Chris Borjis
    February 26, 2009 at 6:02 pm
    yeah the kona down converts a little better than software
    and in realtime.
    yes compressor can produce excellent results for DVD video.
    cinemacraft or other encoders are not necessary.
  • Andy Mees
    February 27, 2009 at 2:19 am
    two sayings spring to mind …
    garbage in, garbage out
    and
    you get what you pay for
    https://www.kenstone.net/fcp_homepage/cinema_craft_encoder.html
    cheers
    Andy
  • Doru Iacovescu
    March 3, 2009 at 8:43 am
    Yes, on paper looks attractive. But which is the best option? Hardware downconversion from hd to sd. Or software conversion with cinemacraft encoder? Which one is the best option available. And also offers acceptable rendering times? Thank you.
  • Walter Biscardi
    March 3, 2009 at 1:30 pm
    [Doru Iacovescu] “Yes, on paper looks attractive. But which is the best option? Hardware downconversion from hd to sd.”
    AJA Kona boards. We use them all the time for up / down / cross conversion for broadcast projects. Nothing cleaner than hardware and that’s including Telestream’s Episode Pro which I now own and use.
    [Doru Iacovescu] “And also offers acceptable rendering times? Thank you.”
    Zero rendering time with the Kona. It’s all realtime.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Andy Mees
    March 3, 2009 at 1:38 pm
    Doru
    What is it you actually want to do? To be fair to those poster’s replying to you here you need to be clear.
    In one post you simply ask “Hello! Do you experienced any kind of problems with the hardware based downconversion methods? Intend to buy an decklink hd extreme,but noy know if it s a good choice or not?” and get a good answer (AJA Kona hardware) … but then you ask “Can you achieve that clean, sharp, contrast, hollywood dvd style image with compressor? Is it worthing to invest in Cinema craft encoder plug in for compressor or a a hardware solution as you have?” which is a completely different question. So what is it that you want to do … a quality down-conversion or create a “hollywood” quality DVD? They are not one and the same thing.
    Andy
