Activity › Forums › Apple Final Cut Pro Legacy › Hard Drives: if you were me…
  • Hard Drives: if you were me…
    Posted by E. Eric johnson iii on June 15, 2006 at 11:25 pm
    …what would you buy & where?
    with things changing all the time and a myriad of opinions, what and where is the best place to buy drives?
    btw, i have a granite hot-swap SATA array w/Tempo-X 8 card.
    currently running a pair of hitachi deskstar 400g’s
    thank you for your input,
    glory to the cow!
    e3
    e. eric johnson iii
    eric@lillcreates.com
    lill creates: founder/executive producer
    Water Channel: producer/virtual set operator
    Kent Kajino replied 20 years, 3 months ago 7 Members · 12 Replies
  • 12 Replies
  • Scott Simmons
    June 15, 2006 at 11:31 pm
    I go G-RAID all the way!
    Life is linear. Edit life.
  • Shane Ross
    June 15, 2006 at 11:34 pm
    Depends…what formats of video do you edit? Do you plan on editing in the future?
    Shane
    Alokut Productions
    http://www.lfhd.net
  • E. Eric johnson iii
    June 16, 2006 at 12:04 am
    D’oh!!!
    DVCProHD will be the primary format for this project. 10-bit could sneak in, but i’ll probably bring that in DVCProHD.
    Seagate?
    Maxtor?
    Hitachi?
    WD?
    thanks for the help!
    e. eric johnson iii
  • Aaron Neitz
    June 16, 2006 at 1:10 am
    As a generality, Seagate and Hitachi make good enduring drives. WD and Maxtor have always been a bit untrustworthy IMHO
  • Shane Ross
    June 16, 2006 at 2:26 am
    External drives…G-raid firewire 800 all the way. Wouldn’t trust DVCPRO to anything less.
    10-bit uncompressed? Then you need a SATA Raid or fibrechannel RAID. I have an internal SATA Raid utilizing Hitachi drives…but several external boxes are out there: Burley, Sonnet 500P, Weibetech SilverSATA V. Then Fibrechannel has Medea, Ciprico Media Vault (formerly Huge systems), Apple XServe RAID.
    You can see my internal popsicle stick RAID at my website. The popsicle sticks can be replaced by the G5 Jive cage by Sonnet…
    Shane
    Alokut Productions
    http://www.lfhd.net
    June 16, 2006 at 4:05 am
    that popsicle stick RAID is awesome!!!
    i have a granite digital dual hot-swap SATA RAID setup now. with the Sonnet Tempo-X 8. sounds like the Seagates or Hitachi drives are the way to go. can you recommend a website or retailer?
    thank you,
    e3
    e. eric johnson iii
  • Shane Ross
    June 16, 2006 at 5:54 am
    THis is who I bought the drives from. $289 each.
    Shane
    Alokut Productions
    http://www.lfhd.net
    June 16, 2006 at 6:26 am
    thank you shane and everyone who took the time to respond! all great and useful input… now i gotta go buy some popsicles.
    glory to the cow!
    e3
    e. eric johnson iii
  • David Roth weiss
    June 16, 2006 at 2:25 pm
    [CharlieX2] “As a generality, Seagate and Hitachi make good enduring drives. WD and Maxtor have always been a bit untrustworthy IMHO”
    Charlie,
    This is pure rubbish and it is not supported by empirical data. So, as a generality it is not true, and therefore it is just an opinion.
    DRW
  • Rennie Klymyk
    June 16, 2006 at 3:26 pm
    It seems to me Seagate purchased Maxtor about a year ago.
    “everything is broken”
