Activity › Forums › Apple Final Cut Pro Legacy › hard drive question!!! yikes!
Posted by Ben Oliver on March 14, 2006 at 11:28 pmjust bought a couple of hard drive enclosures and cheap western digital 250 gig, 7200 rpm drives…
they came pc formated, i made them ntfs on my buddies PC, and i can get them mac formated on my g5, but cant get them formated
mac os extended (non-journaled)
why? any ideas? i try to do it just osx extended, and it keeps journaling them. i cant copy a file bigger than 890mb…
they are usb2.0 enclosures.
Dave Mac replied 20 years, 6 months ago 5 Members · 8 Replies -
Chris Tompkins
March 14, 2006 at 11:44 pmR U using the MAC Disk utility? Format the drive Mac OS Extended NOT Journaled it should work fine. Do they come up on the desk top of the G5 now?
Ben Oliver
March 14, 2006 at 11:54 pmive been trying, i try to format it osx extended not journaled, buyt it reverts it back to journaled….
could it be a jumper setting?
David Roth weiss
March 15, 2006 at 12:12 amGet Cocktail, a freeware utility, and turn journaling off after formating.
Ed Dooley
March 15, 2006 at 12:30 amYou can disable Journaling right in the included Disk Utility. Select the disk and go to File/Disable Journaling
Ed[David Roth Weiss] “Get Cocktail, a freeware utility, and turn journaling off after formating.”
Ed Dooley
March 15, 2006 at 2:12 pmI didn’t get that from his post. It sounds like he’s formatting it Extended, but it’s
showing up Journaled. I don’t read where he tried manually disabling it in Disk Utility,
but hey, what do I know? 🙂
Ed[David Roth Weiss] “He evidently can’t do that Ed.”
Ben Oliver
March 15, 2006 at 2:49 pmyeah…its odd.
i am trying to format it, os extended, non journaled. and i do that, and it formats it, but it keeps reverting back to journaled. i triued to turn it off with cocktail, but i can’t copy more than 890 megs onto a the disc (for editing this is bad, of course)
anymore ideas, other than send these drives back?
Dave Mac
March 18, 2006 at 9:19 pmBen,
[ben] “they are usb2.0 enclosures.”
No one has mentioned this fact….
I would send the drive enclosures back. USB is not a good choice for working with video media files. Get an enclosure with FW400/FW800 ports. USB uses a burst protocol that is not as efficient as FireWire for transferring large files.
I am not sure why you are having trouble copying such a large file. A USB issue with the enclosure? There may also be an issue related to copying large files over USB from within the Finder.
A couple more suggestions (once you get FW enclosures):
- You may want to use Disk Utility and erase your drives with the “write zeros” security option (it will take a few hours to complete). This forces the mapping of bad blocks on the drive and helps to ensure that you are starting off with a pristine drive with no known issues.
- Using the Finder to copy and move large files is somewhat haphazard, in that the Finder doesn’t verify copies. Better to use a back-up/synchronization utility (with a copy verification ability).
- Also, with OS X 10.4, and later, the issue of journaling causing trouble is an “urban myth.” Too often, advice is given to disable journaling on media drives, but, in fact, it is only needed as a last resort when trying to eek out the last bit of performance from a disk subsystem and has nothing to do with reliable operation of FCP using journaled disks. Check out Sean Cullen’s FCP book for more info.
Best regards,
Dave
