Activity Forums Adobe After Effects Happy Thanksgiving; Light Sweep on Nissan Emblem
  • Happy Thanksgiving; Light Sweep on Nissan Emblem
    Posted by Tim Bowen on November 22, 2006 at 8:32 pm
    Hi Folks,
    I’ve created a mock Nissan commercial with the chrome emblem at the end. I want to make that smooth light sweep that goes over part of the chrome emblem at the end, but am not satisfied with what I came up with. I’ve tried CC Light Sweep, and BCC Light Sweep…. maybe my settings are wrong, but it doesn’t quite look the same. Any suggestions??
    http://www.timbowen.com
    David Modijefsky replied 19 years, 9 months ago 5 Members · 10 Replies
  • 10 Replies
  • Chris Smith
    November 22, 2006 at 9:00 pm
    Looking at it, they modeled that in 3D and created a reflection map and a moving light source that your seeing reflected in the emblem. Then in composite stage they added a specular glow around the brighter elements (ie the moving light sorce) and they match moved a blue lens flare with an anamorphic streak over the light sorce (reflected in the emblem) then faded out the lens flare halfway through.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Chris Smith
    November 22, 2006 at 9:12 pm
    Merry X-mas:
    https://sugarfilmproduction.com/NissanEnd.mov
    Download it. Don’t try to play it in your browser. It’s D1 specs Animation codec Quicktime.
    Chris Smith
  • Andrew Kramer
    November 22, 2006 at 9:56 pm
    I played it in my browser. What do you think of that!
    Andrew
  • Chris Smith
    November 22, 2006 at 10:15 pm
    I’m sure it will play. But since I didn’t compress it for web and make it progressive download I didn’t want it to seem like the link doesn’t work as it sits there for probably a good while.
    But you are a dangerous man, Andrew. 🙂
    Chris Smith
  • Andrew Kramer
    November 22, 2006 at 10:43 pm
    Danger is my middle name or Leon.
  • Tim Bowen
    November 23, 2006 at 1:09 am
    so then,
    thanks for the input. But, I’ve built this thing in Photoshop and AE; any suggestions on keeping it in AE with some kind of filters or something. I’ll try something based on what you said…. DON”T FORGET THE CRANBERRY SAUCE!!!
  • Chris Smith
    November 23, 2006 at 3:56 am
    Are you just doing this as an exercise because I just posted you the ACTUAL Nissan ending uncompressed so you can have the real thing.
    Chris Smith
  • Tim Bowen
    November 23, 2006 at 7:23 am
    I’m doing it as an exercise/spec piece for my reel…. awesome to get the actual footage though! THANKS. I still would like to get some tips/suggestions for achieving the effect as I am trying to learn more AE stuff.
  • Jack Hilkewich
    November 23, 2006 at 6:19 pm
    You could add a beveled edge to the layer’s alpha of the logo and then animate the position of the shadow with in the bevel, to try and match the light sweep motion. Adding a bevel onto the logo that already has one built in may look weird but if you could make the logo flat and then add a beveled edge in AE then it may look ok. Could also try a drop shadow and do the same with it’s shadows position.
  • David Modijefsky
    November 24, 2006 at 8:46 pm
    Any chance on a tutorial on stuff like this? Andrew? Aharon?
