Activity › Forums › Adobe Premiere Pro › hand-entered Dropframe TimeCode?
Posted by Chris Harlan on January 8, 2014 at 8:39 pmHey all!
I’m trying to modify timecode on a clip, which works, but I seem to have no way to specify Drop frame or NDF? Am I missing something? Or is this a bug?
John Pale replied 12 years, 8 months ago 3 Members · 4 Replies -
Andrew Kimery
January 9, 2014 at 12:34 amWhat is the frame rate of the footage? 23.976, for example, only exists as NDF. Have you tried entering the TC using a colon vs a semi colon?
Chris Harlan
January 9, 2014 at 12:46 am[Andrew Kimery] “What is the frame rate of the footage? 23.976, for example, only exists as NDF. Have you tried entering the TC using a colon vs a semi colon?
“Lol. Well, of course, you whippersnapper. I’ve been using TC afore you was born. No, the semicolon doesn’t take. It was the first thing I tried. I’m trying to match some window burn which is NDF, and the modify command only seems conscious of DF. Also, I can only enter TC for first frame, even though there is a checkbox for current frame. The checkbox is grayed out.
My guess is that Modify TC is currently sort of non-functional, but I’m checking around before I enter a report. Anybody have different experiences?
Andrew Kimery
January 9, 2014 at 5:34 pmHey, sometimes people over look the obvious answer (ex. I recently fixed a friend’s ‘malfunctioning’ speaker by re-seating the audio cable).
You might be right about the feature being half baked.
John Pale
January 10, 2014 at 3:53 amI’m pretty certain that not all codecs are supported by this feature.
