Activity › Forums › Apple Motion › half renders
  • half renders
    Posted by Jan Boersma on May 20, 2010 at 8:02 am
    I’m trying to add a Motion Master template to a
    Final Cut Pro 720p50 timeline:
    “Satin Blue-Lower Third Pal”
    First I open the template as a copy in Motion to
    change the settings to XDCAM EX 720p50.
    When I click ok, I can see the preset switch to:
    Preset: HDV 720p25, this is confirmed when I go back to the
    project properties, it just switches back to HDV 720p25.
    (Motion Preferences is set to XDCAM EX 720p50 by the way).
    Anyway, when I save it as a new template it looks fine in the
    FCP timeline, the preview plays fine but when I render,
    the template “freezes” after 3 seconds (total duration is 6 seconds). I also tried applying the standard Satin Blue-Lower Third Pal, without trying to change to 720p50 (which switches to HDV 720p25 anyway), same thing happens: plays fine in preview (orange bar showing in timeline) but after render template freezes after 3 seconds. Finally, I tried copying the XDCAM EX 720p50 footage to a DV Pal timeline and here everything works fine, in preview and after render. Any Ideas?
    Thanks, Jan
    (Motion 3.0.2)
    (Final Cut Pro 6.0.2)
    Mark Spencer replied 16 years, 4 months ago 2 Members · 3 Replies
  • Mark Spencer
    May 20, 2010 at 1:07 pm
    You can’t take an SD template and just change the project preset to an HD preset and expect the template to work correctly – it won’t. What you can do is go ahead an embed one of the existing Motion DS templates into your HD project and then scale it up in FCP to fit – of course, it will be soft. You may also need to change the way FCP renders Motion projects for best results: Sequence > Settings > Render Control tab.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Jan Boersma
    May 20, 2010 at 1:19 pm
    Thanks for your reply,
    I solved the problem as follows:
    -created a new project in Motion with XDCAM EX 720p50 settings
    -opened “Satin” SD Template
    -“dragged” Template Layers into XDCAM EX project’ layers
    – saved XDCAM EX project as template
    After that I could just apply the new template in FCP,
    works perfect,
    thanks,
    Jan
  • Mark Spencer
    May 20, 2010 at 3:27 pm
    And you didn’t have to resize or adjust any of the SD elements in the HD project? I don’t see how that’s possible.
    Mark Spencer
