Activity Forums Maxon Cinema 4D Hair via X-Particles Rendering Bizarreness
  • Hair via X-Particles Rendering Bizarreness
    Posted by Ryan Paterson on July 11, 2015 at 1:36 am
    I’m trying to do a relatively simple setup with hair render applied to cached x-particles. The XP setup is basically just a branch object and a trails object, but the render output is… bizarre. What should be thin strands are rendering as giant bulbous tubes.
    Initially I thought this was a glitch in Octane Render (scene is set up to use that) but then I ran it through the other renderers and got the same result. What’s weirder is that I have other scenes with very similar setups that are rendering just fine. If someone wants to take a crack at it, I’d be very grateful.
    9037_badhairday.rar.zip
    Adam Trachtenberg replied 11 years, 1 month ago 2 Members · 4 Replies
  • Adam Trachtenberg
    July 11, 2015 at 4:31 pm
    Very strange. It renders incorrectly in the viewport and picture viewer, but if I open the Octane live viewer it renders correctly.
  • Ryan Paterson
    July 11, 2015 at 5:07 pm
    I know! I posted to the Octane forums and nobody knows what the heck is going on either. I’m just going to rework the scene to use a couple sweep nurbs instead, but I would love to know what I did to break this scene so bad!
  • Ryan Paterson
    July 11, 2015 at 6:09 pm
    Well, it seems I’ve found a solution… If i disable “Spline” in the Hair Render options, and then set Cloning to 1 in the Hair Object and zero out the root settings, it actually renders as it should. Kinda hacky but, I’ll take it!
  • Adam Trachtenberg
    July 11, 2015 at 9:05 pm
    Good job. 🙂
