HAIR + proximal shader not workin on generate mode
Hi guys!
I have a simple set up where I control the lenght of my hairs with a proximal shader.
If I go in Hair/generate tab and I choose “square” for my type of hair, the proximal shader stops working. probably because it is not using anymore the hair material
Is there anyway to control the generated geometry using still the hair material with a proximal applied on it?I have attached a scene file for reference.
cheers!
pu
