Activity Forums Maxon Cinema 4D Hair multipass not working like I want it
  • Hair multipass not working like I want it
    Posted by Maxim Fischer on October 4, 2017 at 2:07 pm
    Hello guys,
    I am trying to render the Hair as a multipass. In the Hair Render settings I changed the Alpha to Separate and then enabled Post Effects in global Multipass.
    Then i got this:
    With the alpha channel I can see through the Head. The alpha channel renders also behind objects and this is my problem. I want the alpha channel as a luma mask in After Effects but like that it wont work.
    Jeremy Solterbeck replied 7 years, 5 months ago 2 Members · 1 Reply
  • Jeremy Solterbeck
    March 13, 2019 at 3:01 am
    Yup. Same issue. Sorry I don’t have a solution for you.
