Activity › Forums › Maxon Cinema 4D › Hair (Fur) trough transparency
  • Hair (Fur) trough transparency
    Posted by Leandro Cattani on January 14, 2009 at 10:16 am
    Hello everyone!
    I’m trying to render a grass made with Fur trough a transparency shpere, but it doesn’t render. Inside of the sphere is always black.
    What’s wrong?
    Thank you!
    Leandro
    Nicola Gastaldi replied 12 years, 6 months ago 3 Members · 4 Replies
  • Randy Johnson
    January 14, 2009 at 11:16 am
    I had that problem once but only when there was refraction in the glass material I think I ended up converting my hair into polygons and that worked….but then you loose the dynamics of the hair.
    Hopefully someone else can answer you properly.
    /randy
  • Leandro Cattani
    January 14, 2009 at 11:19 am
    Hey Randy, thank for the trick. I’ll try it, but how can convert the hair into polygon?
    Thank you!!!
    Leandro
  • Randy Johnson
    January 14, 2009 at 11:35 am
    In the Generate Tab of the hair object change the type “type” then it will render. You can still use wind and stuff on it too. You can also make it editable. You will however loose the Hair material.
    There is a a tutorial here that lets you know about a few more advanced hair options too.
    https://www.c4dcafe.com/ipb/index.php?autocom=downloads&showfile=464
    /randy
  • Nicola Gastaldi
    March 20, 2014 at 2:22 pm
    Hi guys, I know it’s an old thread, but I hope it could help other people too.
    In Render Settings – Hair Render, just tick the box “Transparency” and “Reflection/Refraction/Traced Shadows” and you’ll be able to render it without geometry.
    Cheers!
    gasta
