Activity Forums Maxon Cinema 4D Hair cache calculation doesn’t stop
  • Hair cache calculation doesn’t stop
    Posted by Natalia Chebotar on June 18, 2020 at 12:15 am
    Hi guys! Could you help me, I’ve got a problem with hair object and I can’t find a solution anywhere.
    I have a complex object with hair (a lot of!), dynamics and hair-to-hair collisions. I clicked “Calculated cache” in the hair object, it went through all the frames, took more than a day. C4D didn’t respond all that time, but it didn’t crash (the current frame changed, everything looked fine). But now it started calculating again from the first frame! And it still doesn’t respond.
    I have no idea what to do. I don’t know how to stop the process, and I don’t want to force quit the app because it will destroy all the cache and I’ll waste too much time to calculate it again.
    Any advice?
    Natalia Chebotar replied 6 years, 2 months ago 2 Members · 2 Replies
  • Sam Treadway
    June 18, 2020 at 2:14 am
    Sometimes there is a way to send requests when the frame advances. You can keep pressing or try holding down command+W. If the scene has changed at all since the last save then this will invoke the “do you want to save changes….” dialog. The great thing is that once that dialog is active, command+W will no longer work until you click a button.
    Save the file, close and reopen it. If you pressed play then reopening will continue to play forward which could be a problem. In that case, create a new scene and merge the original into it.
    This could be an issue with display in the viewport vs collision calculation time. Do you have the hair display mode site to guides or the actual hair lines or geo?
  • Natalia Chebotar
    June 18, 2020 at 8:45 am
    Oh thanks! I like the Cmd+W idea, trying it now. Tried to click it a few times, didn’t work, so I just put a couple of erasers on the keyboard and a heavy book on top of them, waiting for the result ?
    I don’t think it is the viewport issue, it’s set to show guides only.
