Activity › Forums › Maxon Cinema 4D › Hair
Hair
Posted by Shawn Smith on February 9, 2010 at 1:00 pmWhen I try to move the hair object around for placement it’s locked in that one spot. Any suggestions?
Brian Jones replied 16 years, 7 months ago 2 Members · 3 Replies -
Brian Jones
February 10, 2010 at 12:50 amare you trying to move the hair from the object that it was created on?
Brian Jones
February 14, 2010 at 1:39 amyou can clear the Link in the Guides tab (or delete the original object) and then move the hair but not with the Move tool, I think it can only be done with the Hair tools. In the Hair menu set Mode to Roots then you can use Hair/Tools/Move to move the hair. The problem is the only thing that will render (without tweaking) is the guides since the hairs are usually interpolated between the guides but need a surface to determine the start point (a poly usually). You can still have hairs bit you have to do it in the Cloning tab of the Hair object, set Clone to something non-zero then spread them out at root and tip with the Root and Tip settings. Still acts as hair.
If you only need static hair the other way to do it is to Generate poly or spline hair and make that editable then that object will be moveable with normal methods
