Activity › Forums › AJA Video Systems › hack or kluge to get DVD output via Kona??
  • hack or kluge to get DVD output via Kona??
    Posted by Bob Flood on May 25, 2006 at 4:23 pm
    Hey yall
    have a kona LH as well as an IO LA and i wanted to know, other than using mac desktop, if there was some hack, kluge, or even a different player that would allow me to see my DVD playback on my NTSC monitor (via kona lh or firewire)
    i looked at echo firew and it does not refresh fast enough as it really meant for stills
    thanx
    bee eph
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Erik Lindahl replied 20 years, 4 months ago 7 Members · 10 Replies
  • 10 Replies
  • Leigh Jewell
    May 25, 2006 at 5:19 pm
    You could use a program like MPEG Streamclip (https://www.alfanet.it/squared5/mpegstreamclip.html) to rip the DVD. It would then make it DV footage which you could put into Final Cut and output.
    Leigh
  • Bob Flood
    May 25, 2006 at 7:43 pm
    thanx Leigh
    true. but i was looking for a way to see my VIDEO_TS on an NTSC monitor un-re-ripped. I am having issues with authoring a dvd and i have to keep burning
    discs everytime i change a seting
    bee eph
    Bob Flood
  • Jeremy Garchow
    May 26, 2006 at 1:41 am
    Look at the bright side, Bob. You’ll have a nice set of coasters, or materials for a cool art project at the end of it.
    What issues are you having and why can’t you just watch the DVD in DVD Player before you burn it? That way the only thing you are wasting is gigabytes which are fully replenishable.
    Jeremy
  • Bob Flood
    May 26, 2006 at 3:17 am
    Jeremy
    Yeah i got so many coasters i should open a retaurant supply company 🙂
    its all about intelace vs progressive
    i am getting artifacts which are not showing up until i see the video on an ntsc monitor
    strobing and such. and i don’t know exactly where they are coming from
    I export an 8 bit uncomp qt out of fcp and it looks fine
    i take it into compressor and suddenly it gets strobe-y, like its being de interlaced. I am sure if i wrap my head around it i can figure it out, but it would be nice to watch my dvd file on an ntsc monitor.
    anyway, i may try squeezing it to see if its any better
    thanx again
    bee eph
  • Jeremy Garchow
    May 26, 2006 at 3:24 am
    Is your footage interlaced or progressive from FCP? Are you encoding interlaced or progressive in compressor? You say you are exporting uncompressed, so I assume you are working in a 720×486 timeline, are you sure Compressor is cropping the image correctly (4 lines off of the top and two off of the bottom)? If not you are reversing the field order and could maybe produce the strobe you are seeing. Are you using a compressor preset or a custom setup?
    Jeremy
  • Mike Johnson
    May 26, 2006 at 9:37 am
    there is a thing called DVD-RW/DVD+RW….
  • Aaron Neitz
    May 26, 2006 at 5:30 pm
    I had to make a custom setting in Compressor for Mpeg-2 with Lower fields. The presets always had weird interlace artifacts.
  • Mike Johnson
    May 27, 2006 at 12:46 pm
    if you render out using odd field first on source that’s recorded with even it will look very wierd. Or the other way around, even when there is odd.
  • Steve Connor
    May 28, 2006 at 10:24 am
    Definately a field issue!
  • Erik Lindahl
    May 28, 2006 at 1:58 pm
    I’d love to see this feature as well. Video out through DVDSP would “rock” simply put. Yes you can burn the discs, but that’s a hassle and I don’t have a DVD-player connected to my SDI-monitor.
    Converting DVD/MPEG2 back to editable video isn’t a solution at all.
