Activity Forums Telestream H264 wrapped into a MPEG2 TS
  • Craig Seeman
    March 28, 2011 at 6:45 pm
    You haven’t posted enough info so I’m forced to guess you’re trying to stream to iOS device.
    I really don’t know your resources so all I can do is throw out possibilities.
    If you stream to a Wowza server using Wirecast rtmp, the server can be set to do this for you.
    Services like Livestream and Ustream can also do this for you with proper settings.
