Activity › Forums › Adobe After Effects › H264 widescreen render problem
  • H264 widescreen render problem
    Posted by Brian Scott on November 13, 2009 at 5:51 pm
    I’m having a problem with H264 renders from AE. All of the combinations I have tried have either given me a vertically elongated 4×3 render, or a 4×3 that is letterboxed.
    I’m working with an NTSC widescreen comp. I have tried checking and un-checking the “Stretch” option (set to widescreen). In the format settings I have set the aspect to square and widescreen. None of these combinations has resulted in a true widescreen aspect. They all look correct in the AE comp window, but look wrong when I play them back. Can anyone shed some light on this?
    Brian Scott
    President
    Image Design Productions, Inc.
    Walter Soyka replied 16 years, 10 months ago 3 Members · 2 Replies
  • Andy George
    November 13, 2009 at 8:58 pm
    Hi Brian,
    In order to create a NTSC Anamorphic (wide-screen) image it
    has to be a non-square pixel aspect ratio (1.22)
    and quick time player does not deal in non-square pixels.
    So the vertically elongated 4×3 render should be the correct one.
    If you bring it back into after effects it should display correctly
    there or in an NLE that can accommodate non square pixels.
    If you want to display it correctly in quicktime open
    the file hit CMD+J select the video track turn off
    “preserve aspect ratio” and change the
    scaled size to 864×576
    -Andy
  • Walter Soyka
    November 13, 2009 at 9:05 pm
    Also, video encoding is not AE’s strong suit — for example, it cannot do multi-pass encodes. You’d be better off rendering a lossless movie from AE and compressing it with a dedicated compression application. encoding
    Walter Soyka, Principal
    Keen Live, Inc.
    Presentation, Motion Graphics & Widescreen Design
    RenderBreak: A Blog on Innovation in Production
