Activity Forums Adobe After Effects h264 via AE or Media Encoder
  • h264 via AE or Media Encoder
    Posted by Craig Rogers on May 8, 2012 at 8:35 pm
    I’ve read more than once that I should render my projects in After Effects in an uncompressed format and use Adobe Media Encoder for h264 files.
    I already had an h264 render from After Effects done for a Vimeo upload. It was set up per vimeo compression specs (5 Mbps) and artifact-wise it’s very clean. The color and contrast is a bit washed out though.
    I ran it again through Media Encoder and the color is the same (flat), but the compression artifacts are horrible! On top of that, the file size is a bit bigger.
    Any ideas why the compression artifacts are so much worse when I use Media Encoder, and why in both cases I’m losing contrast and color saturation?
    Craig Rogers replied 14 years, 3 months ago 2 Members · 3 Replies
  • Dan Fredley
    May 9, 2012 at 4:58 am
    It sounds like you are compressing a compression, which is probably why you are getting such bad artifacts. Do uncompressed from AE then run it through Media Encoder. I would actually suggest compressing it with MPEG Streamclip–free from squared5.com.
    Dan Fredley
  • Craig Rogers
    May 9, 2012 at 6:44 pm
    I worded that badly. I took my uncompressed render and ran THAT through AME. It looked like dookie…and in either scenerio the color of my h264 renders are washed out. ???
    I’ve noticed a considerable difference in the look of a video depending on the player playing it as well. They look more washed out played back with Quicktime. VLC player not so much.
  • Craig Rogers
    May 9, 2012 at 11:33 pm
    I found this info regarding quicktime gamma issues. This “fix” did make my videos play back properly (gammawise), but this can’t be the real issue, as 99.9% of quicktime users aren’t going to know about this “fix”.
    How can the single most popular codec (h264) not work properly with the single most popular player (quicktime)? I’m baffled.
