Activity Forums DaVinci Resolve H.264 to ProRes422HQ vs Uncompressed to ProRes422HQ – No difference?
  • H.264 to ProRes422HQ vs Uncompressed to ProRes422HQ – No difference?
    Posted by Jason Jones on January 17, 2013 at 5:50 am
    I tested the new Canon 1D C today. I expected a vast difference in “gradeability” between the H.264-to-ProRes422HQ I’m used to from my 5D III, and taking a clean, uncompressed HDMI signal out of the 1D C, and recording on a Blackmagic shuttle drive to ProRes422HQ.
    Should be a significant difference, right? There was no discernable difference whatsoever. Couldn’t see it on the scopes, couldn’t see it toggling back and forth using a reference wipe. This was true of both the before- and after-grading clips.
    Why not?
    Jason Jones replied 13 years, 7 months ago 4 Members · 4 Replies
  • Robert Houllahan
    January 17, 2013 at 6:43 am
    Most likely because the camera hardware is doing the demosaic work and the signal is 8-bit. The limitation is probably more in the camera hardware, line skipped sampling noise and other camera issues plus the 8-bit signal than the post camera compression.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
  • Sareesh Sudhakaran
    January 17, 2013 at 3:38 pm
    Because there isn’t a difference usually, as long as the specs are the same. Here’s my more detailed answer: https://wolfcrow.com/blog/comprehensive-guide-to-rigging-any-camera-7-external-recorders-part-1/
    https://www.wolfcrow.com – Workflow information and support for filmmakers, photographers, audiographers and videographers.
  • Joakim Ziegler
    January 19, 2013 at 11:33 pm
    As Robert said, the signal is probably 8-bit, and most of the camera’s internal image processing is applied to both the compressed video and the HDMI out. So range and similar things should be the same, I assume that’s what you mean by “gradeability”.
    However, what you should see improving are compression artifacts. If you try to record very shaky handheld on a dSLR, or generally very chaotic images like close-ups of fast-moving water, etc., there are usually a LOT of compression artifacts and blocking, and the ProRes shouldn’t show any of that.
    Joakim Ziegler – Postproduction Supervisor
  • Jason Jones
    January 20, 2013 at 7:36 pm
    Very helpful – thanks a bunch, Joakim!
    So that’s an additional test I need to make: a comparison betwen the internal H.264 codec and the external ProRes, shooting a scene where EVERYTHING in the frame changes radically. Nice.
    Cheers!
    J
