Activity › Forums › Apple Final Cut Pro Legacy › h.264 to ProRes into FCP via Compressor nightmare
  • h.264 to ProRes into FCP via Compressor nightmare
    Posted by Johnny Smith on January 28, 2011 at 1:06 am
    So i got 274 5D mark ii files (264) that i need to convert to ProRes 422 for FCP and After Effects.
    in Compressor i click on add file icon and select 10 files (tried 100 files and it crashed) but once i drop a generic ProRes on them it dies a slow and I assume painful death.
    Please, tell me I don’t have to convert 274 files one at a time??
    I got 2×3.2GHz Mac Pro with 3TB array, 16GB memory, os x 10.6.6, and CS5.
    Paul Jay replied 15 years, 8 months ago 6 Members · 6 Replies
  • David Roth weiss
    January 28, 2011 at 1:35 am
    You need to make and use a “droplet” in Compressor. Rather than spelling the whole process out, may I suggest that you look in the Compressor manual or in the online manual in the help menu.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Olin Padilla
    January 28, 2011 at 1:46 am
    I personally find that compressor has a lot of issues with larger batches.
    In this type of situation I would use MPEG Streamclip (free), if only for the simplicity and reliability.
  • Jeremy Garchow
    January 28, 2011 at 1:47 am
    Batches of 30 or so should work.
    Setup 9 batches of 30 and submit then one at a time.
    You don’t have to let them finish before submitting the next one.
  • Peter Mcauley
    January 28, 2011 at 3:36 am
    Just the other day I used FCP log and transfer (EOS 5D plugin) on 173 5D clips without a hitch. It also added time of day timecode and reel numbers from the CF card numbers. I believe FCP is using compressor anyway.
    Peter McAuley
    AXYZ
    Toronto
  • Johnny Smith
    January 28, 2011 at 4:43 am
    thank you thank you.
  • Paul Jay
    January 28, 2011 at 9:23 am
    And if you use compressor and you have a 8-core or more machine, you can also create a Compressor Cluster in system preferences/qmaster.
    This way you can use all your cores with Compressor jobs.
