Activity Forums Adobe After Effects H.264 Render Problems
  • H.264 Render Problems
    Posted by George Robbins on April 4, 2011 at 10:29 pm
    Rendering out file with H.264 SOMETIMES has frame order problems, and then other renders is perfect. Of course client is now waiting for render and it decides to do all the time. I can render out QT Animation no problem, but it is frustrating.
    George Robbins replied 15 years, 4 months ago 61,501 Members · 1 Reply
  • George Robbins
    April 5, 2011 at 2:38 am
    Thanks for you answer, but I am hoping for more specifics. I have rendered the same comp several times with no troubles. True, the footage in there is probably the worst you can imagine, codec-wise. Yes, I can work around it, but it takes TIME to render out QT and then compress, vs. rendering a compressed file in the first place. What troubles me is that the error is inconsistent, sometimes appearing and sometimes not, but mostly when client is waiting for an encode. The other strange thing is that the render is read as “30.1” fps by the player.
    ~G
