Activity Forums Apple Final Cut Pro h.264 / proxy / optimized workflow question
  • h.264 / proxy / optimized workflow question
    Posted by Alex Mallis on July 9, 2014 at 7:54 pm
    Pretty excited about 10.1.2.
    I’m shooting a c100/5diii. I have a couple questions about best ingest/export practice:
    1. If I create only proxies, and then choose 422 for my final export, will the conversion be sourced (right word?) from the original files, or the proxies? Does this matter?
    2. If I only use proxies for footage originally shot h.264, am I at a disadvantage when adding color correction vs using optimized 422? Alt phrasing: Are the proxy files more compressed than the original media? Would it make a difference to upres further to 422 if I expect to add color in the edit?
    3. Related to question #1, if I intend to pass off a project to a colorist, is there any reason not to edit in proxy and then export a prores422 of only the final cut?
    Thanks a mill
    Hugh Chaloner replied 12 years, 1 month ago 2 Members · 2 Replies
  • Alex Mallis
    July 15, 2014 at 6:39 pm
    bumpsky
    Alex Mallis
    AnalectFilms.com
    brooklynfilmmakerscollective.com
  • Hugh Chaloner
    August 14, 2014 at 12:58 pm
    1. yes, it does matter, recreate from originals.
    2. proxies are compressed to f*ck, so if fine detail is important to your eye when setting a colour correction, then yes, you should colour correct using the ProRes media
    3. no, there’s no reason not to (how many negatives can we get into a sentence?)
    http://www.intercuts.com
    (m) +353 (0)86 603 0987
