Activity Forums Adobe Premiere Pro h.264 encoder (in cs3) produces really bad aliasing from AVI MJpeg source
  • h.264 encoder (in cs3) produces really bad aliasing from AVI MJpeg source
    Posted by Jason Mongue on May 24, 2009 at 9:22 pm
    I have many 640×480 mjpg avi files from a Canon Powershot camera that I put in a 640×360 project. I keep the vids at 100% scale and just leave them cropped top and bottom.
    What I find interesting is that when I encode my project out using h.264 (keeping the same 640×360, square pixels, ridiculously high bitrates, etc etc) I great really terrible aliasing. If I use MPEG2 (with basically the same settings, though obviously much lower bitrate), it looks fantastic and quite similar to my original videos.
    Can anyone enlighten me as to why this is? Is there some secret setting in h.264 that I’m missing?
    My project settings are:
    Timebase: 30.00 frames/second
    Frame size: 640×360
    Pixel Aspect Ratio: Square Pixels (1.0
    Fields: No Fields (Progressive Scan)
    The AVI files show these properties in Premiere:
    Type: AVI Movie
    File Size: 50.4 MB
    Image Size: 640 x 480
    Pixel Depth: 640
    Frame Rate: 30.00
    Source Audio Format: 11024 Hz – 8 bit – Mono
    Project Audio Format: 48000 Hz – 32 bit floating point – Mono
    Total Duration: 00:00:28:05
    Average Data Rate: 1.8 MB / second
    Pixel Aspect Ratio: 1.0
    Jason Mongue replied 17 years, 3 months ago 2 Members · 2 Replies
  • Terry Kampowski
    May 25, 2009 at 11:21 am
    I’ve never had any luck using Adobe’s CS3 h264 conversion.
    I use Quick Time Pro – it does a great job.
  • Jason Mongue
    May 25, 2009 at 8:34 pm
    Thanks for the suggestion!
    Sure enough, I tried (same settings) using QuickTime (selecting h.264 codec) and the results are excellent. No appreciable increase in aliasing at all.
